difference between vn/vp/vr buicks
Discussion in 'General' started by VryNeat, Apr 5, 2009.
  1. VryNeat
    VryNeat New Member
    perth wa
    VL EXEC
    i didnt know what section to put this in so i just put in general if its wrong i apolagise and feel free to move it
    im sure this has been covered before but yeh just to clarify what are the main diifferences between the buicks of these series
  2. alien
    alien New Member
    Tullamarine, Vic
    03 VY Supercharged 3.8L
  3. VryNeat
    VryNeat New Member
    perth wa
    VL EXEC
  4. VryNeat
    VryNeat New Member
    perth wa
    VL EXEC
    thats power info but apparently theres a diff in compression and the ecu i think so just wanted to know that stuff
  5. alien
    alien New Member
    Tullamarine, Vic
    Hmmm, i know the cams are the same, but that's about all i can rememebr off the top of my head that differs from Wikipedia! I can't seem to find the manual on those older vehicles! :( Looks like i've oly got VS-VY now! :( Anyone with a manual want to post up?
  6. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    vn has different cam, crank, balance ahaft, intake manifold ,exhaust manifolds and tune than vp.vp heads allso have an extra hole for the pcv valve which is moved into the inlet manifold on vp upwards.vr is the same slight mods to flow here and there different cam as well and if auto has a cam postition sensor in the front timing cover and a different tune again for vr engines
  7. VryNeat
    VryNeat New Member
    perth wa
    VL EXEC
    so in saying that is the vr engine better all together? theres a vr at work im buying thats got a ****ed head and rear seal so im just replacing the engine its belonged to a women so its been treated well but yeh will there be bulk issues if i drop a series 2 vn buick or vp buick in?
  8. delcowizzid
    NZ
    в∞ѕтεכ √&
    if its VR auto there will be work require installing the vn-vp engine as they dont have the cam sensor and the vr tune is way off for a vn-vp engine as well would need a custom tune to suit vn-vp engine and vr auto setup if its manual sweet chuck the engine in and slap in a memcal out of the same series ecu all done.vn engines had the coolants sensor in a different place too and will require the wires being redirected to the sensor if you run vn engine on the vr harness
  9. VryNeat
    VryNeat New Member
    perth wa
    VL EXEC
    its auto so essentially ur saying i should just get the vr engine
  10. delcowizzid
    NZ
    в∞ѕтεכ √&
    i myself would slap on some head gaskets LOL but yes better to just get a vr engine will save so many hassles in the end
  11. VryNeat
    VryNeat New Member
    perth wa
    VL EXEC
    the fact that the rear seal is GONE means itd be smarter to just drop in a new motor
  12. padrickz88
    padrickz88 Rick =]
    sunshine, melbourne
    VN V6, nothing special
    vn-vp run 8.5:1 and the vr runs a compression ratio of 9:1
    also apparently the vr came out with the supercharged rods from the states...
    delcowizard pretty much explained it all :) (i think)
  13. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Old thread I know but I see VR have higher comp. can anyone tell me the difference in the heads that makes the VR higher comp? I have a couple of what I think are VP heads and I want to have them tricked up to suit VR plus maybe a tad more comp above stock VR.
  14. delcowizzid
    NZ
    в∞ѕтεכ √&
    Vp and vr are same comp the pistons were closer to deck height than vn that has them quite far down the bore at tdc
    losh1971 likes this.
  15. losh1971
    North Tas
    VR Ute V6
    Excellent, I will have no issue then using the heads off my spare engine on my DD. I'd like to have some reshaping done and it will be better if I don't have to wait to have the heads recoed and ported.
