Front fascia buttons repair or replacement on 09 Ve sv6
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Fili, Nov 11, 2019.
  1. Fili
    Fili New Member
    Ve sv6
    I've been trying to find out how to go about repairing my front fascia buttons . I tried to do it myself ended up stuffing the buttons on it cause my aircon button wasn't working. Went to get a different fascia from wreckers and they said I'd have to change the whole thing.no idea where to start forgot to ask them for more info. Any help would be great thanks
  2. vywgn
    vywgn Active Member
    1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
    Wrecker is full of it get the fascia and swap it, it's only the main unit that's the issue as it's vin coded
    Fu Manchu likes this.
  3. Fu Manchu
    Fu Manchu Well-Known Member
    WA.
    Slug powered VZ, a VE Calais & your mum.
    You can't easily fix the buttons unless you are an electrical enthusiast.
    I tried on a series 2 facia. It comes apart ok but the AC buttons didn't just come off. Some knobs did. Not all.
    For the buttons, you have to unscrew the back of the facia and carefully dismantle the facia. Take photos as you go. Give the parts a clean with Isopropyl Alcohol or contact cleaner. Reassemble using the photos you took.
    To be honest, I would get another facia from a different wrecker. They might be reluctant to sell a facia without the headunit, maybe thats why they said you need the whole thing.
    The facias are not linked to the car as mentioned, you can just swap them.
  4. timd29
    timd29 Active Member
    VE Calais V S1 International 6.0
    Is that only for series 2? In my s1 calais when I swapped facia it still had security lockout and had to be linked, didn't need VIN but did need a re-program to link it to system.
  5. Fili
    Fili New Member
    Ve sv6
    Cheers man I'll go to another wreckers and see if I could get one
  6. Fili
    Fili New Member
    Ve sv6
    Ye
    Yeah I kinda unscrewed the back and pulled off not as gently as I should of but cheers man I'll try another wreckers and see if I could get one
  7. Fili
    Fili New Member
    Ve sv6
    Finally got a front fascia without the head unit. But they only had one and it was a omega ve ‍♂️
