Help Decoding Build Plate
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by LawnPotato, Jun 3, 2019.
  1. LawnPotato
    LawnPotato New Member
    Pakenham
    VH SLX
    Hey everyone, I've got a VS ute as a donor and I'm trying to find out if its a VSII or VSIII. Its probably as simple as the year but I could'nt find anything telling me what year was what. Anyway its a VS ute 5.0l manual, I think its an S pack as it has cruise, tacho and bucket seats.
    Model: VS8VK80-725
    Body: L361375
    Trim: 251
    Paint: H114
    Engine:LB9
    Trans: M34
    Built: 28/07/98
    VIN: 6H8VSK80UWL361375
  2. vs-lover
    vs-lover Well-Known Member
    VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
    Am I correct you are saying you are going to destroy it ? (donor)
  3. FXST01
    FXST01 The Grey Man
    Perth, WA
    VP V6 Exec
    Built: 28/07/98 I don't recall a Series 3 of the VS's.
  4. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    2000 VS ute was a series 3, not sure about 98.
    Lex likes this.
  5. vs-lover
    Series III was only in Utes and LWB (Statesman & Caprice) all the rest finished up mid 1997 as Series II's
    losh1971 likes this.
  6. SL/ENUT
    SL/ENUT The SL/E Fanatic!
    Burnie, Tasmania
    VB SL/E 5L
    Its a Series II ute.
    Paint is Tungsten Pearl
    Motor is 304ci
    Getrag 5 speed.
  7. vs-lover
    It's a series III to be exact as the Series III was released in May 1998 and as this one was built on the 28th of July 1998 this makes it the last variant of the VS ute before being replaced by the VU.
  8. Phillbert
    Phillbert Active Member
    Gold Coast
    VZ SV6, VS L67 Ute, VS Statesman
    Is that just utes? My statesman says series 3 but it is 3/97
  9. vs-lover
    Series II came in September 1996
    Series III Statesman and Caprice came in at June 1998 and went until end of May 1999 and was then replaced by the VT platformed WH,
    The Statesman range didn't exactly follow the Commodore timeline.
    So someone has played with yours and simply put a Series III badge on in place of the S2 badge. Obviously someone at some stage has attempted to extort more money during a sale of the said vehicle.
  10. LawnPotato
    Pakenham
    VH SLX
    Yeah the bodys totally screwed and it's giving its 5l to my VH so I have no problem scrapping it.
  11. LawnPotato
    Pakenham
    VH SLX
    Im mainly trying to find out if its a roller lifter one so i can get a cam package but ill just have to open it up and check anyway.
  12. bevzan
    bevzan Member
    Redcliffe
    VS Ute
    series II had t5 gearbox
    sIII had getrag 5spd, the other difference being the injection type
    on the later series III they ran the roller cam motor with sequential injection.
    early series III ute had getrag with batch injection (i have this type)
    your vin breakdown as follows
    6H8 VSK80UWL361375
    6h8= General Motors Holden (World Manufacturers Identification)
    VS = model VS
    Luxury Code:
    K: Executive
    Body Style Code: 80 : Ute
    U engine coode 5.0l inj. (M is Vt sequential roller motor)
    W is model year code 1998
    L is for Adelaide Plant
    last 6 digits are build number
  13. vs-lover
  14. exec24
    exec24 Active Member
    SA
    VY Berlina Series 2
    your VS ute is a early series 3, the early series 3's built up to December 1998 has this same setup as VS series 2 and were not all roller cam
    VS series 2 came into effect 03/06/1996
    VS series 3 came into effect 04/05/1998 (non roller engine) these are mechanically the same as VS series 2 until end of November 1998
    VS series 3 had the XT9 emission upgrade which came in to effect December 1998(these are the roller cam engines) same as VT
    and the engine number on your that VIN has the VU prefix(if it still has that engine), if it was a roller it would have VM as Bevzan mentioned above
    another way to tell is the engine wiring and computer are different to VS series 2, the XT9 option has a airflow meter and the computer has a 3 plug computer same as VT does which plugs in from the side of the computer
    the VS series 2/early series 3 computer only has 2 plugs and they plug in from the bottom, the engine wiring had No airflow meter, but they run a MAP sensor on the firewall on a removable bracket
    My VS is a series 2 executive and i converted it to a 5.0 i used a VS series 3 setup from 03/05/1999 SS ute with the XT9 setup with the Airflow meter setup
    i later had another engine roller engine rebuilt for it and had the Airflow meter deleted and went MAP sensor and kept the factory sequential injection, as the car now runs a Dual plain manifold
  15. EYY
    EYY Well-Known Member
    VS Statesman
    They were a roller cam block as of very late s2, just without the roller cam setup fitted. Heads are the older, larger combustion chamber version.
    I've pulled a couple apart like this. VS S3 Jun 98 with late 97 cast date - VU prefix. I would expect OP's vehicle to have the roller cam block if it's original.
  16. EYY
    VS Statesman
    S3 started a little earlier than that I believe, but definitely finished later in 1999. I know because I had one or two.
  17. exec24
    SA
    VY Berlina Series 2
    well im going by the GM online parts catalogue i use, which decodes VINs too. ive attached a screenshot of a VIN decode of that 1999 SS ute, with the brakepoint dates, as they updated stuff
    VS Statesman are pretty rare with the XT9 option as the WH was released not long after, but utes are a bit more common as VS Utes production didnt stop until the VU came out, same time as the VX. so probaly has another year on the VS Statesman's
    vs-lover likes this.
  18. exec24
    SA
    VY Berlina Series 2
    the engine currently in my VS is a 1998, and previous one was 1997 both were VM prefix with the roller setup fitted, so i quite cant compare... but im guessing possibly holdens started casting them up all the same to save money ...purely a guess though
    did your motors have and any threads or anything for the spider cradle to bolt into, wouldn't the lifter bores be different... bit curious now
  19. vs-lover
    It's probably one of the models with the most conflicting info out there as it was the only model with a Series III being built that ended up utilising equipment from another model (VT) being incorporated within.
    As far as Series II is concerned there is quite a bit of equipment that drip fed into the vehicles as old stock was exhausted such as the change over of the Transmission cooler lines that went from rubber hose slip on to cooler and then changed over to the screw on fittings. Traditionally it's been thought that the change over was at Series II but it was changed over much later during Series II production (around November 1996) if I'm correct.
    The Genuine Service Manuals aren't very precise either except that they use PSN figures (Production Serial Number) to pinpoint the exact change of various components, but no date of when that actually happened.
  20. EYY
    VS Statesman
    Yes - they had the boss and thread tapped in the deck to retain the spider plate, but no spider plate or roller lifter setup. Block itself was the only part that was from the roller cam setup. Can run standard ft lifters in the roller cam block. The 99 model statesmans definitely exist - kicking myself i sold mine now but sold it to a mate so i still get to see it lol. Plus mines got s3 running gear anyway lol.
    I honestly don't think there's an accurate cut off date for the use of the older style engine - it's luck of the draw for 97-98 vu prefix blocks (and can be a cheap way to get your hands on a roller cam block because most sellers look for spider plate/vm or vn prefix)
