[Ecotec] l67 Flywheel question
Discussion in 'V6 Development And Modification' started by King_berald, Jan 11, 2020.
  1. King_berald
    King_berald Member
    VX Berlina Wagon
    hi guys,im doing a manual conversion on my l67 atm and im trying to get the flywheel mirror balanced but i dont have the original auto flex plate from the motor. it didnt come with it. What is going do be my best option? will any l67 flex plate work? or am i going to have to pull out the crank?? motor is out of the car atm.
  2. Utel67
    Utel67 Active Member
    Tasmania
    Vs s3 ute
    Grab another l67 flex plate.
  3. King_berald
    King_berald Member
    VX Berlina Wagon
    I've got one here, but comparing to other flex plates I've seen, they have minor adjustments to the balance. Which has me worried.
  4. Utel67
    Tasmania
    Vs s3 ute
    Grab one that hasn't been messed with.
  5. King_berald
    King_berald Member
    VX Berlina Wagon
    None of the flex plates pictured have been messed with. This is done from factory? I assume every engine is balanced individually?
  6. Utel67
    Tasmania
    Vs s3 ute
    I have swapped a cracked flex plate before with another l67 flexplate and didn't notice any difference.
    Maybe someone else knows more about this and cares to share.
  7. King_berald
    King_berald Member
    VX Berlina Wagon
    I'm hoping that the adjustments are to balance the actually flexplate alone, and are not made in relations to the crank.
  8. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    From what I understand is a flex plate is not critically matched to a crank, however a flywheel is. You need the original flex plate in order to mirror balance.
