Lowering VF on coil springs
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Alz0019, Jul 16, 2019.
  1. Alz0019
    Alz0019 New Member
    Sv6 vf s1
    Hey guys just wondering would it be ok to get lowered springs on stock shocks? I only plan on getting sl all front and back. I read somewhere that they would be fine, but I wasn't convinced enough. Anyone have experience with this?
    Also. What is a suitable price to have springs installed. Anyone know any reputable shops that don't excessively charge?
  2. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    How many km's on the current shockers?
  3. RED LION
    RED LION Active Member
    SA
    VFII Redline
    I've got SSL's on stock springs on my Redline. The ride is great but I understand that the shock life will decrease because of the springs. I'm due for a service is December so I'm probably going to get either Monroe short shocks or Bilstein's fitted. My car has only done 6000km and springs were just fitted.
  4. Alz0019
    Alz0019 New Member
    Sv6 vf s1
    Problem is I didn't buy the car new, so I have no idea if they've been changed before. The current KM's on the car is around 60,000
  5. Alz0019
    Alz0019 New Member
    Sv6 vf s1
    Is it that much of a difference between stock shocks and Monroe shocks? So would you recommend I just buy monroe shocks while I'm at it?
  6. RED LION
    SA
    VFII Redline
    Well the standard ones will wear out quicker. I’m not sure how much quicker though. I'd lean towards doing them all at once if my car had done 60k
  7. lmoengnr
    Sunbury Vic.
    Probably still the factory dampers, and getting on a bit.
    If I was to fit new springs, I'd replace the dampers as well.
  8. Alz0019
    Alz0019 New Member
    Sv6 vf s1
    any shocks in particular I should be avoiding? I've been looking at the KYB, Ultima and Monroe shocks.
  9. lmoengnr
    Sunbury Vic.
    Munroe and KYB are pretty good. Have used Ultima's in small cars, they seem decent.
    I usually recommend Koni's and Bilstein.
  10. RED LION
    SA
    VFII Redline
    I had Monroe’s on my last VF. I’d happily have them again.
  11. Wayne001
    Wayne001 Active Member
    Meadow springs
    Vf calais
    I am running standard shocks on my vf calais wth sl springs front and rear .
  12. Alz0019
    Alz0019 New Member
    Sv6 vf s1
    Mind if you could send/upload a pic of the car. How’s the handling and comfort on the standard shocks?
  13. Wayne001
    Meadow springs
    Vf calais
    Handles good and still comfortable, front could be a bit lower but then would have speed bump issues .
    Can not upload image for some reason .
  14. Alz0019
    Alz0019 New Member
    Sv6 vf s1
    how long have you had them on for and hows the shock wear?
  15. Wayne001
    Meadow springs
    Vf calais
    About 12 months seams all good .
  16. LS1SS
    LS1SS Active Member
    Milperra
    VF Redline.1970 Dodge R/T Challenger 440 six pack.
    KYB rears for VE/VF,they have KYBs for VE front but not VFs as the front struts are not interchangeable between the two and doesn’t look like they are going to make them for VFs either,pity as I had them on my VE and found them brilliant.
  17. SS Flo Rida
    SS Flo Rida Active Member
    Gold Coast
    VF Series II SS W375
    I ran with the factory front struts for about a year before the strut top bearings **** themselves so at the time I thought I’d install the monroe GT short travel struts and found them to provide a noticeable improvement in ride, roadholding and steering when pushing the car harder than normal city driving. For the $ i’d recommend them along with a heavy duty top bearing assembly if keeping the car.
    saroadie likes this.
