POWER BUTTON... does it make much difference at all ??
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Hairy Eater, Apr 3, 2006.
  1. minux
    minux Infidel Bear
    Actually, it will do the 1/4 quicker if mapped correctly, there was no way i could get under 12 without power on, because foot flat it shifted 800 rpm earlier and really didnt get the revs up enough for the next change
  2. SUPERV6
    SUPERV6 SUPERV6 13.299@101.44
    Moonta (SA)
    VT 'S' Supercharged V6
    Yes thats true, but your'e talking custom tune/map there ;) Factory original mapping the pwr/eco button will give you nothing at WOT. Lots of things can be fine tuned with a custom tune/edit in the trans.
    minux >> Did it shift 800 rpm too early before or after tuning?
  3. minux
    minux Infidel Bear
    After, i wanted nice easy driving without power on, but still enough oomph that it would take off ok, but not rev too hard.
    More so in the GEn3's configs, the rev range is different standard by about 200rpm, not a whole lot, but a bit of kick in between shifts.
  4. SUPERV6
    Moonta (SA)
    Yep...so you've set it up basically to do short shifts in Economy. That would give you a softer feel and hence why you would get better results when you do use the power setting.
  5. minux
    minux Infidel Bear
    I see what your saying, however, i also remapped upper rev range, foir me the LS1 is only starting to boogy at 5600, especially after it was cammed
  6. Bill mac
    Bill mac New Member
    Palmerston north
    VR Commodore,95. Acclaim,3.8.
    Thanks,I've never used power button ,but I will if it's more economical around town in my vr
  7. commodore665
    commodore665 expat Saffa
    New Zealand via Cape Town
    2005 SV6 & Alfa Romeo 156 V6
    I don't think it would make a great deal of difference , depends more on how heavy your left foot is
  8. mpower
    mpower Well-Known Member
    right foot i think you mean ;)
    power mode is mostly for shift points. drive the car sensibly and you should be able to use either mode just as effectively.
  9. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 Auto Wagon
    I think it also stops it going into overdrive (4th)? Its for when towing?
    Piet South Africa likes this.
  10. Calaber
    Lower Hunter Region NSW
    CG Captiva 5 Series 2
    Different vehicle but for what it's worth, using the power mode enables the vehicle to shift in to lower gear much earlier, even under light throttle. Our Captiva has an economy mode which tends to hold higher gears too long, so that the car hits an incline, engine speed drops and the eco mode then kicks back two gears instead of just one because the road speed has dropped so much. The Commodore engine has more torque so it can haul up hills much more readily than my weak old 2.4, but enabling it to pick the right gear for each situation makes more sense than forcing it to plug away at lower revs for the sake of economy.
  11. commodore665
    sorry yes I meant right foot
  12. mirrabucca
    mirrabucca Member
    VX S pack (Devil Yellow)
    My VX V6 has a three- window dash. Leaving it set on litres per 100 k's it shows a big difference in instantaneous fuel consumption as the revs drop when it changes up (ie from 3rd to 4th). When I am in eco mode it will shift at about 70 k's. In power mode it shift closer to 80. So there's the fuel saving. Less time spent in the lower gears. Same in my wife's Cruze. You can see the difference whenever the revs drop even though the right foot hasn't moved. This is mainly because the car is doing less revs per kilometer. That's also why these cars seem to have a sweet spot (for fuel economy) at around 100 to 110. At a steady 60 k's my VX is using about 6 litres per 100 k's. At a steady 110 its at 5.4.
    Of course, over 120 and it gets thirsty! And why the big V8's can get incredible economy on a trip. Look at the VS - VY advertised figures. Compare city with country. And compare that with equivalent sized modern cars!
  13. Brettly-2008
    Brettly-2008 Active Member
    Bunbury
    WM Statesman - VE SS Commodore
    No V6 Commodore is getting 5.4L per 100km at 110kmh.
  14. mirrabucca
    mirrabucca Member
    If I could post pictures...
    Best trip was a few years ago (when the engine wasn't worn etc), we went from Canberra to Newcastle. Filled up at Goulburn. Got the Hexam. The average according to the dash was 6.6 litres per 100 k's. Yes, that agreed with the actual pump to pump figures.
    The speedo is accurate (digital) and has been calibrated. It agrees 100% with the GPS, both for current speed and distance travelled and distance to go.
  15. EYY
    EYY Well-Known Member
    VS Statesman
    Power mode is great for hilly areas. Issue is that with standard tuning and not in power mode, it allows the engine to labour too much on top gear.
    When you’re approaching a hill it’ll hold too gear too long before changing down a gear, by which stage it needs to change down two gears. In this case i’d say there are fuel savings to be had in power mode. It’s totally situation dependent.
  16. Brettly-2008
    Bunbury
    OK. What PS1 are you running in your tyres? Is it manual? I've owned plenty of Commodores and I'm OCD with getting bullshit low consumption out of them on long trips (even the SS), but I've never had one achieve lower than low 7s over a decent run. What you're saying is you're getting almost 1300kms out of a tank?
  17. NeddyBear
    NeddyBear Veteran Mountain Biker
    Queensland
    2004 Ford Falcon RTV Ute & 2004 Subaru Outback 2.5
    An interesting post, power mode yes I've seen the button but have never turned it on.
