Suspension Advice & Oil Leaks for Blueslip
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Ajeff37, Dec 11, 2018.
  1. Ajeff37
    Ajeff37 New Member
    Buderim
    VZ Berlina
    [​IMG] Hi Everyone,
    I've recently moved down to the Snowy Mountains from QLD and need to get my car changed to NSW rego. My car is a 2004 VZ Berlina Sedan (see picture below), has about 160,000kms on it and runs well. I put it in for a Blue Slip today and it didn't pass (was expecting that) due to the following reasons:
    -Engine oil leak (has been there for the 6ish years I've had the car, every service the mechanics just say it's minor and typical for the cars age and they'll fix it if it gets worse).
    - Gearbox oil leak, possible rear extension housing seal (that's new)
    - I need new rear tyres
    - LH Front strut top has movement
    - Suspension too low
    In regards to the engine and gearbox I know it depends where it is as to the cost but I was wondering if anyone had a rough estimate based on their experiences.
    Tyres, yer they're on the way out. Any recommendations for tyres that would go well in an area that's got a **** tonne of pot holes, snow and there a few gravel roads I use every other week.
    The main thing I need help with is the suspension and strut. The car came lowered when I bought it, haven't done anything with it. I would like to get it raised to pass the Blue Slip as well as gain the ability to drive out of driveways without the car sounding like it's being murdered.
    I'm thinking just the stock height/kit would be best for the area. Does anyone have any recommendations for brands/kits that I should look into that would suit the area I'm living in. Also my current springs are quite stiff I think so something that's going to be useful but not change the way the car handles too much as I'm really used to it if possible.
    Cheers for any help & advice :)
    https://imgur.com/a/xz43rqC
  2. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Trans leak is about 1hr maybe a tad more. The engine leak NFI as you haven't said where it is coming from. As for tyres ask BJTM what they have in the way of Kumhos they are decent and priced well. Just don't have BJ's do the alignment as they might stuff it.
  3. Whiteshark68
    Whiteshark68 Member
    Queensland
    VY Berlina Series II
    i agree with ^losh1971 about the leaks
    as for tyres i would try some Hankook Optimo possibly H426 as your car is a berlina and should be running 16 inch wheels as standard
    i have run Hankook Optimos on every car i've owned for the last 17 years and never had an issue with them
    losh1971 likes this.
  4. losh1971
    North Tas
    VR Ute V6
    I looked at Hankook in 16s but they were a tad expensive, 50 bucks each more than Kumhos but a slightly better tyre so higher price is to be expected.
  5. Whiteshark68
    Whiteshark68 Member
    Queensland
    might be a locality thing because i only paid $115 each fitted and balanced for the Hankooks in the 16 inch and only paid that because i needed them sort of yesterday and only paid $95 each for the last set of 15s i bought and if i remember correctly the Kumhos were about the same price as the Hankooks
  6. losh1971
    North Tas
    VR Ute V6
    That's good price. I paid $115 for Kumhos, Hankooks were $165. What size were yours? I had to get 225/50 R16s. We do get screwed over here on pretty much everything though, due to the 300km water highway.
  7. Whiteshark68
    Whiteshark68 Member
    Queensland
    mine were the factory size of 215/60R16 i prefer to keep my wheels and tyres stock
  8. stick3
    stick3 Active Member
    newcastle nsw
    vz sedan vs ute gsx1400
    to pass a blue slip your car has be like it came from the factory i would just get legal 2nd hand tyres just to pass and to save money because the other things are going to cost a lot if you are going to pay a mechanic to fix them
    than you are going to need a greenslip when your car has pass the inspection
    you can compare prices from different insurance companys
    https://www.greenslips.com.au/calculator.html
    add rego is about 400 plus you need to buy the plates there about 40
    Ajeff37 likes this.
  9. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    Losh's tyre size is a stock factory size.....Unfortunately, the pricing varies between sizes, due to supply and demand
  10. Ajeff37
    Ajeff37 New Member
    Buderim
    VZ Berlina
    Thanks for the information on the tyres. I'll look into that in the local area keeping those tyres in mind.
    For the engine leak, the mechanic didn't mention it in the report. I'm going to call them tomorrow and ask them if they were able to pinpoint it.
    Anything on suspension? That's where I'm most lost.
  11. stick3
    newcastle nsw
  12. Whiteshark68
    Whiteshark68 Member
    Queensland
    I never said that that particular size wasn't stock on a particular model of commodore i was saying that it's not stock on my car
    it works out to be the same size as mine but that size wasn't a factory fitted tyre for my car
    as to the OP you will find that the berlina does have fairly stiff suspension even in factory trim
    if it was me i would find out if the shocks have been replaced with shortened items then try to find a set of factory spec springs and shocks.
    can't help you with recommendations on springs as i have never lowered any of my cars but i used to always use Munroe Wiley shocks but if they have gone the way of everything else i expect they will be crap now:(
  13. vc commodore
    south australia
    vc commodore
    You quoted a price for a different size tyre to Losh's size.....This is what I am getting at
