Sv6 2005 no crank
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Oscar2020, Jan 23, 2020.
Tags:
  1. Oscar2020
    Oscar2020 New Member
    Lilyfield
    Vz sv6
    Hey guys, I’ve Got a new key about 3-4 months old and recently replaced the slip ring. When I go to start the car it starts well when it’s cold but when it’s warmed up it won’t start. For example driving to the petrol station was all good. When I went to start it again the car wouldn’t crank and I was stranded for about 40minutes until it finally started. When I turn the key the dashboard gets power and the radio. And the power train issue come up and sometimes traction control.
    Any advice on what it could be? Thanks
  2. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    Ecu on its way out
  3. Oscar2020
    Lilyfield
    Vz sv6
    Thanks, ill get it checked out
  4. Fu Manchu
    Fu Manchu Well-Known Member
    WA
    VZ V6
    Neutral safety switch getting dicky?
    Old battery?
    Dodgy ignition switch?
  5. Oscar2020
    Lilyfield
    Vz sv6
    The battery has a green light on it which shows that it is healthy. However I’m not familiar with the neutral safety switch or the ignition switch. Could either of them toss up the engine warning?
  6. Fu Manchu
    WA
    VZ V6
    If the warning light comes on, get it scanned and find out what the code/codes set are that triggered the warning light.
  7. Oscar2020
    Lilyfield
    Vz sv6
    Yea the codes that I got were for the slip ring and key. But I have replaced both of these for new one and still have a power train light
  8. 99notout
    99notout Active Member
    VZ Equip Wagon
    If the powertrain light is on, there is still at least one code still set.
