V6 Crankshaft Info
Discussion in 'V6 Development And Modification' started by 383 hatch, Nov 4, 2007.
  1. chrisdoesitbetter
    chrisdoesitbetter | → ³8°º™ ← |
    VR 3.8L
    i know it may sound like im repeating a question but ive read several posts with conflictiing answers. i have a series 1 VN with all manual conversion parts. i have a VR that i want to trans plant it into if i understand correctly, the Vr had the 8 bolt flywheel, therefore will the T5 bolt straigh in? can someone that has done this tell me staright up?
  2. OZ38
    OZ38 Member
    Jurien Bay WA
    VS V6 T5 & VY V6 M35 UTE
    I could stand to be corrected here but, I believe if the VR doesn't have a Ecotec engine in it (from a transplant or whatever) then it will have the same bolt pattern (6 bolt) on the manual crank as the Series 1 VN V6 manual ?
    Anyone confirm if I'm right or wrong ?
    Deek
  3. OZ38
    OZ38 Member
    Jurien Bay WA
    Ok I done some more reading a i think the VN / VP T5 had a 6 bolt flywheel & then maybe the VR T5 got changed to a 8 bolt flywheel. Then the VS T5 also got a 8 bolt flywheel but has a different mass balance to the VR Flywheel.
    Deek
  4. 383 hatch
    383 hatch Well-Known Member
    Cowes, Phillip Island
    Deek, if you read the first post it will tell you. VN Series 1 is the only V6 with the 6 bolt pattern (both auto & manual, just different patterns). From VN series 2 onwards all V6's use the same 8 bolt pattern (including Ecotecs).
  5. OZ38
    OZ38 Member
    Jurien Bay WA
    Thanks Tim,
    Yeah sorry for being lazy as I should have gone back to the start for the correct info.
    Deek
  6. 383 hatch
  7. OZ38
    OZ38 Member
    Jurien Bay WA
    Ha ha no I didn't take it that way at all Tim, it's all good info.
  8. vpcalais6
    vpcalais6 F#%ING [P] PLATER
    central coast
    V6 manual vp Calais
    Hey mate because the vp s2 and the ecotec share the same bolt pattern does that mean I can use a ecotec flywheel on my vp s2 for my manual conversion
  9. OZ38
    OZ38 Member
    Jurien Bay WA
    Not a 100% on this because they are different engines whether the balance of the flywheels would be different. But for my way of thinking the heavier mass of the later ecotec flywheel maybe of benefit to the VP engines balance.
    Deek
  10. vpcalais6
    central coast
    V6 manual vp Calais
    Would I be able to get it balanced the same as my flex plate and do you have any idea of where I can get one
    Thanks
  11. OZ38
    OZ38 Member
    Jurien Bay WA
    Yes.
    You could talk to this bloke as he sell new ones to suit as ChevTorque flywheels for the ecotec V6
    ChevTorque V6 Conversions in W.A. - (08) 9493 2769
    Speak to Adrian May.
    Deek
  12. vpcalais6
    central coast
    V6 manual vp Calais
    Thanks for that mate
  13. klampy
    klampy Member
    coffs harbour
    Mazda E2000 V6 convert
    crank swap
    so the bolt patterns have been ironed out, but is it possible to swap VR S2 crank with an ecotec crank? i know for a fact that the oil pump drive is the same between them as i have a VS double row timing chain in my VR. and the engine is NOT an ecotec..... my "thinking out loud" asks if an ecotec crank would fit in the 3800 block...??
  14. PanthaVS
    PanthaVS New Member
    VS S-Pack SII
    I'm looking at doing a VS SII Ecotec auto-manual conversion... everywhere i read... VN this... VN that... Of the little info i can find on VS... If i get a getrag, and get all the bits required... am i right in saying:
    the only thing i need to do/alter, to make it fit is get the crank flange drilled and 2 dowels put in (To stop the 8 bolts being sheared off) ?
    If i am right in saying this, does the crank flange come off the crank? because if it does, i can take it somewhere to get it done.
    Also, what exactly is "mirror balanced"?? I'm having trouble making sence of what it is? and if its needed on a VS SII ecotec? (again... VN this... VN that....)
    oh... i know about the different spigot bush, starter motor and flywheel, i know about the manual ecu/loom and auto inhibitor problem, so yeah... im asking PURELY how to "physically" make it fit...
  15. OZ38
    OZ38 Member
    Jurien Bay WA
    For starters..
    No the crank flange does not come off.
    The added dowel pins are what GMH did to the crank & flywheels of the ecotec V6 after the VS manual model (VT,VX,VY).
    So really you could get away without drilling for the dowels (others have).
    The VS manual flywheel will bolt straight up (just make sure it suits a Getrag Clutch Pressure plate).
    Mirror balance just means you give the engine balancer people your flexplate off you present engine, with your new flywheel. They then just copy (mirror) the balance from flexplate settings onto the new flywheel. So the new flywheel suits the engine balance.
    Deek
  16. Rusty-Tim
    Rusty-Tim Rusty-Tim
    Chch NZ
    VN Ute, VN wag, VR sed, VN sed, HX Tonner, HA Viva
    So another kind of related question. I have just blown up engine bigtime in VN series 1 manual. I have a spare series 1 auto. Is it possible to just put the manual crank and therefore flywheel etc in the spare auto engine? Do they run the same size big ends and crank journals, front seals and rear seals etc??
  17. cander24
    cander24 New Member
    NSW South Coast
    VZ GTO. VS LS1.
    The crank/flywheel dowels were also fitted to a series 2 VS manual crank. Well, atleast they were in my factory manual anyway ;)
  18. OZ38
    OZ38 Member
    Jurien Bay WA
    Yes your correct. I should have said after the VS T5 model. As the Getrag equipped Ecotec engined models all have the dowels in crank.
    Deek
  19. mattyr82
    mattyr82 New Member
    nthn suburbs, vic
    2009 colorado diesel 4wd automatic. 2010 mazda 3
    so are the dowels on the flywheel or the crank? if they are supposed to be on the crank....u just bolt up ur flywheel, and mark where the dowels holes are to be drilled with a texta thru the dowel holes on the flywheel.
    if the dowels are on the flywheel, use a piece of thick paper or cardboard and spear over dowels in flywheel, mark and drill/cutout bolt holes....transfer to crank, mark and drill.
  20. turbo_vp_v6
    turbo_vp_v6 New Member
    charters towers
    vp 3.8
    Will the manual loom from a series 1 vn plug into a 92 vp. have a series 1 vn manual that i want to put into my vp.
