VF Sv6 Sensors not working
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Papadoc, May 9, 2019.
  1. Papadoc
    Papadoc New Member
    VF SV6
    Hi all, I have a VF Sv6 but both the front and back sensors don’t work. The reverse camera works fine however there isn’t any beeping whatsoever. How can I fix this?
  2. snortings
    snortings Active Member
    Queensland
    MY15 SV6
    Check the settings in mylink (could be set to towbar attached if you don't have one etc).
    Good way to test the sensors would be to try an automatic park, if it won't let you or just won't activate at all then there is probably something up with the sensors. Maybe try disconnecting the battery for 10 minutes, I read another user had this problem and disconnecting and reconnecting the battery after 10 minutes fixed the problem.
    Hope this helps.
  3. Papadoc
    Papadoc New Member
    VF SV6
    unfortunately I’ve already tried changing around the settings and nothing will work. Yes automatic park won’t work either, I’ll try the battery method and see how it goes. Thanks for the help
  4. snortings
    Queensland
    MY15 SV6
    No worries, let me know how it goes.
  5. TheEnvelope
    TheEnvelope New Member
    Blacktown
    SS-V Redline VFII
    Just wondering how this worked out?
  6. Papadoc
    Papadoc New Member
    VF SV6
    Hey mate, it didn’t work so I ended up taking it to get looked at and as it turns out something wasn’t plugged in correctly. Problem is fixed! Thanks for the help anyway
