VS Ute Central Locking
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by IsBenny, Jul 22, 2018.
  1. IsBenny
    IsBenny New Member
    1995 VS Executive Ute
    Hey everyone, be warned I'm car illiterate :S
    So my question is when I push the button on my key for my 95 vs Ute my interior light comes on but no doors unlock. I'm sure I'd have central locking because I can't manually lock my driver side door without it being closed.
    Fuees are all fine.
    Any suggestions?
  2. stick3
    stick3 Active Member
    newcastle nsw
    vz sedan vs ute gsx1400
    it hasn t got it and you can only lock your drivers door when its shut so you don t your keys inside
    mine was the same until i fitted after market central locking
  3. IsBenny
    IsBenny New Member
    So what's with the interior light coming on when I press the button? Just a way to find you car at night or something?
  4. stick3
    newcastle nsw
    thats about it in a nut shell, central locking was an option on the series one utes and made standard on the series two
  5. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    My VR ute had central locking. It wasn't working though so like Stick I fitted an aftermarket kit as it was gonna be hard finding the problem. My ute also has cruise though so may have had some upgrades fitted when purchased new.
  6. de_overfiend
    de_overfiend Beef is Good
    Tweed Heads
    VS Calias
    do you hear the actuator trying to unlock the door or does the lock button move at all? Probably a faulty actuator or the plug in the bottom of the actuator is loose or corroded.
