Vt series 1 5.0 error codes help
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Drgt1974, Jan 7, 2019.
  1. Drgt1974
    Drgt1974 New Member
    Vt berlina wagon S1 5.0 + vn berlina sedan 5.0 man
    Hi all first time poster
    I’ve got a 97 Vt 5.0 series 1 berlina wagon
    Got airbag light on dash
    Had clock spring done 2 years ago
    I changed front seats few months ago for which I disconnected battery
    Light has never been on before now
    Just out of blue yesterday
    I checked and got error code 35
    Now in my searching I’m finding two different errors for same code?
    One says 35 idle error eg Iac valve
    Other 35 says drivers seatbelt pretensioner?
    Im not sure which is correct
    I’m thinks seatbelt one as airbag light is on?
    Cars running fine
    Are Vt 5.0 error codes same for series 1 and 2?
    I know v6 and v8 the same
    Just not sure why I’m coming across 2 different error codes 35
    Can’t find a definitive answer
    Any help appreciated
  2. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    That is correct,
    35 Idle speed error (IAC valve unable to control idle speed)
    May need cleaning, Or the plug is lose or the wires are damaged,
    Or may need to be replaced.
    Drgt1974 likes this.
  3. Drgt1974
    Drgt1974 New Member
    Hey thanks for the reply
    Yeh that’s what I’ve come across
    But I’ve also come across a code list for Vt v8 that says 35 is seatbelt pretensioner?
    Which makes sense cause my airbag light is on?
    I’m getting code 12 and 35?
    Come across this list?
  4. immortality
    Sth Auck, NZ
    You have a couple of option to confirm the diagnosis. Seeing as it is the ABS light it is probably the pre-tensioner.
    Your options are to either take it to a workshop who have the correct scanning gear or you can get a cable and software from Envious Customs (site sponsor) which can diagnose the ABS system and give a more definitive answer to what the exact fault is and possibly reset.
  5. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Are you using a scan tool to get the error codes? The major components of the VT and subsequent Commodore models, such as the engine/trans, ABS, SRS (airbag), and instrument cluster, have their own processors/modules and their own series of error codes. The codes between modules are not unique. As you have discovered, code 35 can have one meaning for the engine/trans and another meaning for the SRS (airbag).
    If you are using the paperclip method, you can display engine/trans codes by bridging pins 5 and 6, and ABS codes by bridging 5 and 12. But you can't display SRS (airbag) codes without using a scan tool.
  6. Drgt1974
    Drgt1974 New Member
    Hey thanks heaps for the info
    Yes exactly what I thought
    The different systems have different error codes but possibly same numbers
    All makes sense now lol
    So yeh I think I got an srs error and a engine error
    So I think the 35 I’m getting by bridging pins 5 and 6 is the iac idle error
    And although airbag light is on I have not yet seen the actual error code relating to that error.thinkg of investing in an envyous customs ALDL cable and engine/srs kit $110
    Not bad considering my guy wants $50 to read and clear code once lol no brainer I reckon
    Thank you for your reply
  7. Drgt1974
    Drgt1974 New Member
    Thanks so much for your reply
    Yeh I’m looking at enyvous customs kit right now $110 for ALDL cable and engine/airbag scan kit which will tell me exact srs code and clear it not bad considering my guy want $50 to read and clear code just once good investment I think
    I’m sure it’s seatbelt pretensioner
    And 35 code I’m seeing now relates to the iac valve
