VZ Berlina BCM
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by aussiesvz, Feb 19, 2016.
  1. aussiesvz
    aussiesvz Austin Button
    Boronia
    VZ SVZ Wagon
    Have everything for climate control conversion and have made up a custom loom from a Calais loom and an SVZ loom and the conversion is ready to go apart from the BCM.
    The Calais BCM is no good because it doesn't support a rear wiper which is essential in the wagon.
    Does anyone have a VZ Berlina wagon with factory climate control? Just need to know what stage BCM and what number to get and I'll be ready to go! All you have to do is look under the driver's side dash with a light and you'll be lending a massive, massive hand!
    Cheers in advance
  2. oska
    oska Active Member
    vx custom 600RR
    if BCM has power windows then the rear wiper is also available by default
    BCM's are different between models and some extra wiring looms may need to be added and modified to work with lower models
    a TECH2 can switch it on
