Vz sv6 miss fire
Discussion in 'Just Commodores Polls' started by Vs statesman2003, Jan 20, 2020.
  1. Vs statesman2003
    Vs statesman2003 New Member
    South Australia
    Vs statesman
    Vz sv6 has mis fire... used to only have misfire undeload eg between 80 and 100kms
    Recently replaced plugs and coils and since then it has a rough idle constantly after about 10 seconds of running... any help would be much appreciated
    Parts replaced
    Throttle body
    Plugs
    Coils
    Fuel pump
    Fuel filter
    Vacuum lines
  2. Gridlocked
    Gridlocked Member
    2017 VFII SV6 Commodore
    Apologies if I missed it but are you able to connect a scanner and check what if any codes it may be throwing up? You appear to have covered the obvious parts, I would've pegged it as a coil. It may be an issue with a failing signal line to a coil? I'd be checking for codes first before throwing any more money in parts at it.
