Wanting advice on V6 sidi exhaust
Discussion in 'VE Holden Commodore (2006 - 2013)' started by AntonioNicola, Dec 1, 2015.
  1. AntonioNicola
    AntonioNicola New Member
    South Australia
    VE berlina
    Hi guys, still relatively new to this site. I'm a bit of a noob when it comes to this kind of stuff but I couldn't find anything specific to my enquiry.
    I have a 2010 berlina, 3.0L sidi. I've made it look nicer than the grandma spec it comes stock. Been lowered, tinted windows, Calais tail lights and front bumper And chrome twin tips on both mufflers. The only thing wrong with it is that it sounds just wrong. Has absolutely no sound to it. Need it to sound like it looks.
    I'm not looking for performance enhancing or anything ridiculous (any performance is a bonus), simply after a bit of nice sound to the exhaust and not wanting to end up with the infamous droning sound. I know it's a V6 3.0L and some would question why I would want such thing. I'm not here for opinions, I'm here for advice.
    What size exhaust comes stock on my car, and what size should I get? Will it require a different size fitting if I go bigger or can it just be bolted straight on. After a cat back replacement, nothing like headers/extractors whatever. Brands to lean towards/avoid?
    Thanks so much in advance for taking the time, and sorry for such a long post.
  2. Xplaya
    Xplaya Active Member
    NZ
    HSV
    I have a VE SS Catback with SS Non AFM Mufflers on my sv6, no middle muffler with an x-pipe (Doesnt drone for me,.) I do wish it was a little bit louder sometimes, maybe delete the x pipe with a straight?
    but i love it compaired to stock, Best way to describe it gives a natural sound to it, like how it should sound straight from factory (What i dont get about this though, is that its from an SS, yet every stock SS is quiet?
    I hear you can go as high as 2.5 " without drone? I wouldnt mind giving it ago, but dont want to put in the money just to say i dont like it :)
  3. AntonioNicola
    South Australia
    VE berlina
    Thanks for replying! Sorry for sounding like an idiot, but what is AFM/non AFM?
    Also, how you said it was a nice natural sound is kind of what I'm after! I always thought a V8 exhaust would sound horrible on a V6. So a 2.5" cat back with deleted middle muffler with x pipe would sound nice, you say?
  4. Xplaya
    NZ
    HSV
    Sorry just to clarify i have not tried a 2.5" exhaust :) I just heard that is as far as you would want to go with the ve V6, but i have not tried this, and wouldnt know..
    Mine is a stock SS catback (2.25") with an x pipe (But i dont know if the x pipe is really necessary when it comes to tone, mine just came with it)
    Aparently VE SS and SV6 have the same catback with different mufflers. Maybe the berlina is the same so you may get away with just putting on the SS mufflers :)
    This is a NON AFM Muffler
    http://tinypic.com/view.php?pic=2ni8dpx&s=8#.Vlz6dEZERnA
    This is a AFM Muffler
    http://forums.justcommodores.com.au...factory-afm-mufflers-sedan-wagon-img_0324.jpg
    One has 2 single pipes at the rear of muffler, the other has a single U connection
  5. AntonioNicola
    South Australia
    VE berlina
    Ah ok I get it now. That would mean my stock is an AFM single outlet, I've added twin tips to it. I imagine there would be some differences between them sound/performance wise?
  6. Xplaya
    NZ
    HSV
    i was just showing the difference of AFM mufflers vs NON AFM mufflers by looking at the tips. As i heard the AFM mufflers drone?
    Sound wise yes you should hear a difference :) and because they come with twin tips will also look good. Performance wise, wont be much different if at all
  7. AntonioNicola
    South Australia
    VE berlina
    Would I be better off just buying 2.5" sport mufflers purely just for some noise and saving hundreds of dollars or is it worth the full cat back?
    sorry for so many questions! i just want to be sure before spending money, as i don't want it to go to waste obviously
  8. Xplaya
    NZ
    HSV
    I would only go full SS catback and mufflers if you can find them cheap, (I bought mine for $20) otherwise just try the SS / HSV mufflers and see if you like the tone? (i just dont know if the catbacks are the same in berlinas compaired to SV6 and SS so dont know how they will line up.
    Then if its not loud enough then try an aftermarket sports muffler?. Not_abba_fan knows whats good with aftermarket systems.
  9. Blurem
    Blurem New Member
    SV6 VE Series II Commodore
    If anyone has a pair of SS mufflers that'll go onto me Ve II sv6 and wants to help me out, it would mean a lot, in Sydney.
  10. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    I'd go with the SS system first, the non AFM one with the twin pipes out of the muffler, not the single pipe with twin tips. You can have the front muffler cut out and replaced with straight pipe as it already has a couple of small hotdogs there. It should sound pretty good. I throw these systems away so any exhaust shop should give them to you.
  11. AntonioNicola
    South Australia
    VE berlina
    I think I'm just going to go with the twin pipe rear mufflers to start with and work off the sound that gives it and work forward if I want more. I took them off both sides and started the engine and it has quite a loud sound to it, so if I just tune that with a set of rear mufflers it might be enough. Can anyone advise what material to use? Either stainless or mild steel, I kind of like the black painted mild steel as it hides the resonator rather than chrome. But if stainless is better sound then will go for that. Also, is xforce a good way to go, or redback. Both fairly cheap, just want to know what people think comparing the two. Thanks
  12. Ben Ten
    Ben Ten New Member
    VE II SV6 Commodore MY12
    I have an sv6 sidi and was in an identical situation to you 3 months ago, copping **** and getting the "just buy a v8" advice so i know where you're coming from
    In my experience i've found most of the stock catback to be pretty good and the only thing holding them back are the rear mufflers.
    If you're looking to do a very cheap and highly effective swap that will give you good sound, nice tone and no drone, i'd change the rears to either xforce or redbacks.
    I picked up a secondhand pair of redbacks for $150 and absolutely love them, would highly recommend
  13. AntonioNicola
    South Australia
    VE berlina
    Thanks for the tip mate, yeah I'm 19 and I love my car and don't want to get rid of it. I don't have the money for a V8 and I really don't need that amount of power nor can I afford how much fuel they use.
    Was your rear mufflers stainless or what? I have only seen them in black mild steel so I assume they're that. Also, what size did you go?
  14. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    check the v6 exhaust thread at the top of the start page, lots of info, I have a set of non afm mufflers but am in brisbane
  15. Ben Ten
    Ben Ten New Member
    yeah they were the black mild steel and only 2.5" but they sound pretty sweet.
    if you want super crazy loud i'd just go for straight through pipes with no mufflers on them but i've only seen them on 3"
    mine bolted straight on and the whole thing took maybe an hour and a bit with a mate and a tiny bit of screwing around with no mufflers on ;)
    yeah i'm only 20 and still on my P's so I Feel for you man
    love the car and want to keep it around for a while!
  16. oky
    oky New Member
    2012 sv6. my12
    hay the easy way and cheap way is to just replace your front exhaust pipes to 2.25 as the stock ones are 2.0 and the back pipes already 2.25 and just get some ss rear mufflers from the wreckers
  17. AntonioNicola
    South Australia
    VE berlina
    So I bought redback 2.5 inch rear mufflers with twin pipes and put them on in less than half hour. Happy with the sound. Gives a loud sound and no cabin drone at all. Thanks for the advice
  18. Ben Ten
    Ben Ten New Member
    no worries mate :)
    happy to help!
  19. AntonioNicola
    South Australia
    VE berlina
    Here's my car after install
  20. AntonioNicola
    South Australia
    VE berlina
